Fob Trouble!
eebobobo
Hello.
I know this has been asked before, and I have seen the posts about the sequence to use to reprogram a fob.
However the problem I have is slightly different. This is on a 1998 Avensis CDX Hatch.
When I try to lock the car with the fob, it will not lock the car, but does arm. When I press to unlock the car, it does try to unlock, and disarms, so the unlocking part seems to be ok.
Also, if I do arm the car with the lock button, then open a door, the indicators start to flash, but I am getting no siren.
Has anyone else had this same problem? Thanks in advance,
Ian.
