2007 Avensis T3S 20 D4D
waza
hi every one , just recently bought second hand from main dealer and just wondering if there is anything i should look out for before my warranty runs out. i had 2002 gls vvti for seven years before without any problems at all cheers
Any water in your rear light units - although they may not be covered by your warranty.
Are you aware of the head gasket problem - if not have scan on this section of the forum. Unless you have obvious symptoms, the most important point is to keep the servicing up to date by a reputable garage in case there is a problem in future and you want to take advantage of the "extended" engine warranty for this issue that Toyota have provided (so far).
