My Camry Shakes In Drive
utahman13
You can check these things to make sure that what is the actuall problem. You can check the spark plugs that they are fine and also check that the spark is good. Then you also check the igintion coils which is an important thing to car starting.
Is that a question, a complaint, or just an observation?
Give us something to go on!
Thanks for the responce its a issue im having
it idles smmoth in park or neutral
while stopped it idles rough till
i start driving i have checked my timing
plugs and wires all is good there
was wondering if it may the tras mount
