Retrofit Front Fog Lamps One Mk1 Avensis
Konrad C
Just let you know that a fellow member (Paddy) added front fog lamps to his Mk1 Avensis, with a little help from myself.
The parts needed for the upgrade is a set of front fog lamps, an indicator control which has the extra front fog control, and a relay. All the wiring is already in place, as is the frontfog indicator lamp.
The foglamps go into the bumper replacing the blanking plates.
Paddy emailed me and I gave him some pointers and pictures of the under dash wiring and relays.
After fixing the connections in the foglamps themselves, the foglamps work.
It seems that Toyota use the same wiring loom in most versions of the Avensis to save cost, and add the extras, depending on the specification ie: LS, GL, GLS or CD.
An example is the cruise control added to diesel Auris and Mk2 Avensis.
It shows that anything is possible if the right parts are available.
