Bleed Screw Size
Yatoto
Hi.
Does anyone know the size of the brake bleed screws for a 2006 Avensis 1.8.
I believe the Toyota part no. is 47547-05020 but I'm sure Mr T will charge over the odds for these.
Cheers
What is over the odds? Would you not prefer the correct part specifically made to fit?
The part number has been superceeded to 90069-39000 and is £4.57, best to be safe eh?
Kingo :thumbsup:
I get your point Kingo. The reason I asked the size is that I was thinking of using stainless steel ones.
Cheers
Share the knowledge if you find suitable stainless steel ones. Presume the idea is that they don't corrode and sieze as much?
