56 Plate Auris. Rear Brake Squeel When Reversing
rewerp
I have a 56 plate Auris T Spirit. Whenever I go in reverse, thereis a loud squeel coming from the rear brakes. Ihave have the rear calipers, brakes and discs replaced, but the noise is even worse. Can any one advise what to do next or what the problem is. All I get from the dealer is that the Auris is known for this and they can not do anything about it.
Hi I had this same problem but couldn't find any fix for it on the forums. Just found posts of people with similar problems.
Has anyone had any luck on how to fix this annoying problem?
Just wait and it will disappear with time. Changing the parts will not help.
Of couse you can ask Toyota if they've released some new pads for the car with fixed compound or something.
The pads were modded a number of times, get the latest ones fitted, it did not cure all cars but hey ho, its only in reverse :mellow:
Kingo :thumbsup:
