Bearing, Strut Mounting, Rh
igormus
have just changed the subject bearing due to wear down (clicks on the right side steering when started to move) by 80k
the bearing details -- 48619-42010 BEARING, STRUT MOUNTING, RH
the drive satrted to be more silent
Nice work Igor. You mean at the top of the strut so you had to remove the spring?
yes correct -was forced to lower and compress the spring.
after have assempled -- I recognised that did not make photos as step by step - it is my fault. it is because the day is short and wanted to complete during day light. after got to reliable garage to arrange for wheels alignment.
I did the same on my number 1 - as I was replacing the shock absorber anyway. Not difficult as much as just footery.
