How The Ell Do I Fit My Lexus Style Rear Lights?
Anyone got links for this procedure so I dont break anything ?
Cheers
R.
Lexus lights on a MR2 :crybaby::eek:
Me and G had a play about with his back lights and I think its pretty simple to remove them, he will be along later.
On a rev3 it should be dead easy.... I have a set waiting to go on and I have a rev1 :eek::eek:
Hi mate, I don't condone fitting lexi lights to your MR2 - but here goes anyway ! I used this guide to remove my light clusters-
http://www.imoc.co.uk/technical/howto/rearlights.htm
Ta-da. Re: lexus lights, only joking - they're not to my taste, but fair enough if you like them - its your car!
Hope you find that guide of help.
only problem mite be getting certain light patterns. i know sod all about electronics, so when i get mine ima go dwn to rogue and get them to sort it. bibbbs (on these forums) had his standard rev3 light patterns changed by patrick there who fiddled with diodes or summin which is beyond my electrical knowledge.
Mine extends as far as plug , socket. socket , plug... ah! then plug goes into the socket! 10 mins l8r why isnt this working... another 5minutes, doh! gotta flip that little thing beside the socket to turn the power on, tada, me is happy cos i got it working :), erm now how do u work the video :unsure: ...
-Z
Don't be a wuss....give the wiring a go on ya own ;) To be honest I HATE wiring and I managed sweet as with my 94's when I had my Gen II, just a bit of cutting and re-wiring to get the 94 lighting effect. This may help a bit:
http://mr2.noegruts.com/t-lights/install.htm
Cheers
KiwiMR2
i'm prone to blowin stuff up or breaking it :eek:
i'll usually give it a go myself cos i h8 payin people for stuff i *think* i coulda done myself. but i always end up payin more cos they got like 3 times the amount of work to do to fix what i've done aswel, lol.
-Z
-Z
Seriously Im REALLY bad too, actully in the process of TRYING to change the 91 lighting effect to the oem 94 style I got a few different patterns...one where ALL were on with the park lights on and the 2 outer ones lit up when the brake was on, another were the centres ONLY were on in park & the outsides ONLY when on the break :wacko:
Im pretty sure you can't blow anything but maybe a fuse ;)
Cheers
KiwiMR2
well when i get my lexus rears i *might* give it a go... :)
actually guess im gonna havta, cos i'll fit em in b4 i send my car for a respray, then the centre panel will get sprayed also.
-Z
When I fit my lexus rears I'm gonna keep my original 4 rear light's on configuration as I think it gives the car an 'import' look to it.
but dude ur car is an import... :rolleyes:
-Z
I think he means US import...looks very corvettish with 4 tailights on rev3 clusters. Looks shaweet!
i get ya.
and yep they do look good :yes:
-Z
Jimlads rev1 import doesnt light up like mine. I did mean the jappy look and not the yank look altho thinking about it.. those lexus rears do look a bit corvette.
