Interior Heater Control Not Working
bluebones
hi, my heaters for my 04 plate rav have stopped working and not sure why?, ive checked the control switch and this seams to be ok, i put 12v throught the fan motor and this worked,
does anyone else have any other ideas or where i should check next.
thanks
no ral advice other than to check that your coolant levels are correct (low coolant = no hot water in the heater = cold feet)
.......and have you noticed any irregularity in temp. Gauge reading?
What are you saying? The blower isn't working or it doesn't get hot?
sorry lads, perhaps i didnt explain correctly, the interior fan switch is not working, like i said ive tested the fan motor and tested the control panel and these seam to be ok, just wondering where to look next,
thanks for the replies so far
the blower is not working at all.
I'll find you a wiring diagram. There is probably a relay as well as a fuse.
thanks anchorman, would be lost without people like you :clap:
