Aygo Horn Doesn't Work Help!
My aygo's horn has stopped working. The 10amp fuse is fine and so is the horn when i directly put current to it. Is there any other hidden fuses or relays that i should look at?
Thanks Jim
perhaps the contacts under the steering wheel have a bad connection?
hi steve i hope not because ive heard that the airbag sensors etc are very delicate and can not work.
