Looking For Toyota Avensis 2.2 T180 Upgrade Performance Exhaust Or Tai
AMZAD
HI
CAN ANY ONE HELP I HAVE A STANDARD EXHAUST SYSTEM AND WHAT TO UPGRADE TO A BETTER BIG PERFORMANCE EXHAUST WITH A BIG TAIL PIPE ANY IDEAS WERE I COULD FIND ONE OR JUST THE REAR END PLEASE HELP CHEERS
This is going to be tricky because the style for the big bore back boxes is for the pipe to exit straight from the box ie horizontal. The Avensis is designed for the pipe to bend down towards the ground so you will have to modify your bumper and then reinforce it against flexing/cracking and any heat from the exhaust. There is a risk that your upgraded exhaust will look silly sat in a modified bumper.
pretty sure that TTE used to do a twin tailpipe exhaust but you may struggle to find one these days & if you do find one it'll probably be silly money..
Yes, they made one. Only the price was ridicilous, 1000€ when you buy it new from a Toyota dealer. You dont need to modify the bumber with TTE exhaust.
Any custom exhaust centre should be able to make you a new rear box for not much money.
as above
go custom and get the look and note you want.
let them worry about the rear bumper
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
