2012 Avensis T2 - Sat Nav Retrofit Easy - Plus What Alloys ?
devilhunter
Hi guys.
I have a 2012 T2 Avensis but wondered if its possible to retro fit the sat nav with screen from the TR model as they turn up on a certain auction site fairly often and wondered what was involved in fitting it.
Also the 16" steel wheels have got to go for some 17" alloys so again there are lots for sale that fit previous generations of Avensis - I assume the fitting is the same ?
Thanks guys
obviously fitting bigger wheels than everything is calibrated for will result in an inacurate spedo and poss abs probs
I am only interested in fitting Toyota 17" alloys not boy racer multi fits, as fitted on higher spec Avensis models but maybe from previous generations.
These should have lower profie tyres so the rolling radius should be the same. I was thinking more about the offset etc ?
ok i didnt know u could put diff tyres on to make them the same my bad... if u tell me where the info would be written ill go look on mine:)
coop
The most important part is getting a wheel that is suitable for the stud fixing and the correct offset and wheel nuts. You can go up or down in wheel diameter and then add tyres of the correct profile to keep the overall diameter the same so that the speedometer remains accurate.
There are several online sites that give calculators to work out the permutations available to you. Below is a link to just one such site.
http://www.etyres.co.uk/tyre-size-calculator.htm
To be safe and get the right information I would start with advice from reputable wheel/tyre suppliers.
Have you done a search of this site using the search box up on the top right of the page? I can remember a number of comments about wheel upgrades but can't remember the detail.
The wheels off any post 2008 MK3 Avensis will fit yours as for the Nav I assume you are talking about the post 2012 facelift touch n go system it will fit but you will need the:
Touch headunit
& go nav unit
Wiring harness
Centre dash fascia
Gps antenna
Camera & harness
And microphone unit
Looking at the parts catalogue the T2 is missing all of the above so it could a bit of a headache to make it work
Great reply sir. I may look for a breaker if go down the Sat Nav Route but I will most likely change the car for an estate next year anyway so will hang fire on that. Wheels and tyres are on though as my fronts are getting low.
Touch headunit
& go nav unit
Wiring harness
Centre dash fascia
Gps antenna
Camera & harness
And microphone unit
Another thing sir, would it be possible to list prices with these new so I have some idea on what to pay used (is that a separate headunit and nav unit ?) or can I access the parts catalog and check myself ?
