I Need Immediate Help Please Mot Tomorrow.
chilled
Hi I have a 02 Celica gen 7 my windscreen washers don't seem to work the rear one has never worked since I brought the car but now the front ain't working?
It still makes the sound when I use them but no water? I took the front wheel off and the plastic casing and swapped the hoses over that were on the pump now I have the front working? But not the rear I have a Mot tomorrow morning and now the front work the drivers side jet hits the wiper how do you adjust the angle of them?
Also does the pump how a switch in it which switches from front to rear? Do I need a new pump? I need help asap as like I said mot tomorrow.
The jet adjusts with a small pin or needle inserted into the jet hole, so long as the front jets work when the switch for the front washers is operated then you will pass the MOT as the rear washer / wiper is not part of the test only the fronts need to operate.
Thanks for your reply I just tried the pin in there but didn't seem to do much?
