What Problems Would Slack In A (1Zzfe) Timing Chain Likely Cause?
ThePermanentProject
Hi all,
- i need some real-world experience on this one............
Have started to hear a light, metallic, inconsistent rattle at warm idle recently.
Had the valve-cover off, and can see that there is slack in the low-tension side of the timing chain........
How much slack is acceptable (in the real world), and what (if any) symptoms would this most likely produce?
Best Regards,
- andrew.
Your best bet would be to speak to Se7en Motorsports on Celica-Club. What he doesn't know about the 1ZZ & 2ZZ engines isn't worth knowing!
ok, thanks for the heads-up edwardio - I'll give him a shout :)
