Front Wing Replacement
Colin1447
I have had my front RH wing damaged and wish to change it myself. Has anybody done this job and is prepared to describe the procedure? Thank you in advance
  • 7 months later...
Hi Colin
Did you have any luck replacing the wing? Somebody reversed into mine the other day, so I'm having to go through the same process...
Cheers, Christian
