Starter Motor
rambler
As per title......i may need a new Starter motor..,Have been quoted for Lucas , Denso ? ? ?,and Bosch.
Have never heard of Denso ? ? ?...apparently Toyota use them on our Rav's ? ? ?
Have heard of Lucas & Bosch....think they make good products.
Be grateful for any guideance as usual folks.....
This comes from a reccomended garage from a very good friend of mine ,and the garage is on the same ind est as i work...so its nice and handy
Cheers
There might no be an option of all 3 but I would always choose Denso.
Well,my Rav is being tested tomorrow Don,and just have to see what he reckons.......
I guess Denso is the most expensive then.....as usual,i know you only get what you pay for ?
Amazing how often these can be repaired with a little effort.
Brushes wear down or stick,electrical connections come loose or burnt,dust clogs the bendix etc.
The only time I had to fit a new one was when it did not disengage from the flywheel ring gear and the armature windings were spread all inside the starter.
The customer said I thought it was noisy!!!!!!
Del
My starter motor "went" on my other car. Just clicked when trying to start. Got a £9.99 kit (from www.repairkitsuk.com for example) and its worked for years since!
Dave
