I have a 1992 mr2 turbo i'm sure it has power steering as i thought they all did i was just wondering where the power steering fluid goes as under the bonnet its brake fluid
the power steering fluid cainster is on the opposote side of the Battery as the brake fluid is. You have to lift the bit of plastic trim there and then you can unscrew the cap. Theres two readings on it, if the engine is cold the fluid level should be within the COLD region and within the HOT region if the engine is hot.
Make sure you use the right fluid cos i think in our cars its a bit different since we got electrically assisted P/S...
Can some 1 take a photo of this oil filler as when I bought my 2 they said it had power steering and I do have some kind of filler but my mechanic says it’s for the clutch. :huh:
do you have a light on the dash that say PS in red? when you first turn it on and the goes out?
