T27 Avensis Bluetooth
Valvematic
which audiosystem do you have? standard or navsystem ?
regards,
Peter
try these steps ( found in my users manual of my T27 ) :
push DISC-AUX until BTA is displayed
push TUNE-SEL and select SETUP
using TUNE-SEL select PAIR AUDIO , then RECORD NAME and finally CONFIRM
a code should be given > putt it in your BT-audio device...
Now you can play audio using a BT device :-).
regards,
Peter
Quick question, my bt device for audio is also my phone which is already paired. Can it be paired again for audio and both work thanks
yes both can be paired at the same time. So phone function+audio will work.
push Disc-Aux until BTA and than select it to play music
Still having problems, when I press the disc aux button it won't toggle to bta.
My previous 2009 T27 Avensis with the standard 6disc audio unit did not play BT audio. There was no capability in it for that. Normal phone bluetooth functions worked fine though.
I'm pretty sure that the Avensis did not have that feature in the standard 6disc player ever. Verso got it later on. Rav4 and Avensis got the feature after they were updated with Toyota Touch system.
I don't think it is possible either, I have not been able to do it on many Toyota's until fairly recent models
Kingo :thumbsup:
