Cam Belt Replacement
luckylewa
can anyone tell me when the timing belt needs changing on a 2010 avensis 2.0 diesel?
The car has a timing chain not a belt, so it should not need changing. It should last the life of the engine, so long as the oil is changed regularly. It it known that chains can stretch, the guides and the tensioner can wear.
The diesels changed to chain in 2006.
Yep Konrad is right, Just make sure you change the oil at regular service intervals.
