How Many Litres Of Engine Oil
mokhali
i m planning to do an oil and oil filter change on my 2002 d4d 2.0 avensis but dnt exactly know how much and which engine oil i need.the car has done 82k miles
Just done mine 5.9 litres (2004) to be exact 1cd-ftv. I used 5w 30 oil from toyota.
all this info should be in your user manual.
Can I ask how much Toyota charge for the oil?
Mo
I m sure the 2.0 d4d engine in 2002 avensis and the newer shape after 2003 is different thats why i am a bit confused. Some one told me i have to put 6.4 litres of engine oil thats alot of oil.
put your reg in here.
http://www.castrol.com/castrol/sectionbodycopy.do?categoryId=9024084&contentId=7073092
I selected the same car as yours and it said 6.4 so 'someone' may be right. like I said check your user manual that will confirm or ring your local toyota dealer.
Engine (DT) EDGE 0W-30 (a) 6.4 Magnatec 10W-40 A3/B4 Manual Transmission Universal 75W-90 3.9 Automatic Transmission - Differential From Gearbox Coolant (50%) Radicool 6.9 / 7.1 Brake Fluid Brake Fluid DOT 4 Wheel Bearings Multipurpose Grease
note on the second link
synthetic BLEND is just another name for semi synthetic
probably the exact same oil on the 2 links but the first link obv works out cheaper when buying the 2 lots
just incase you or anyone thought they were semi and fully synthetic
Thanks m8 i checked and now i can crack on with my first time servicing a car
Yeah it is the same oil.
I will change my oil for firs time and checked here:
"put your reg in here.
http://www.castrol.com/castrol/sectionbodycopy.do?categoryId=9024084&contentId=7073092 "
I did it and got disappointed result for my engine 1AD-FTV -requires 6.3l
That means I will need:
2x 5l or
5l+4l or
2x4l or
5l+1l+1l
or 2x4l+5l= 13l for two times change...
