Rivet Size
TheSensibleCookie
Does anyone know the standard rivet size for the Toyota Auris?
I want to replace a few which I've bent out of shape/snapped.
It is for the front grill/air duct which you need to remove to swap out front headlight bulbs.
Thanks in advance.
If you do a search on Amazon for Toyota Auris trim fasteners, two types come up - each type £3.49 for ten
Thanks, I believe it is 6mm. I will order some and post confirmation so if anyone needs some in the future they will know.
Thanks, great idea. Someone may find it helpful in the future, indeed :)
