Acceleration Problems
Arturas21
Hello guys. I have RAV4 D-CAT version XA3 2.2 liters, 130kW. I have the problem with speed up or it is accelaration problems i really dont know. When I fully press acceleration pedal some times my car's RPM increase very slow it goes from 1000 rpm till 2000 rpm very slow. When it reach about 2100 rpm the beast wakes up. but some times it drive well from low rpm. e.g. i drive about 50 km/h with 3 gear, my car rise rpm and speed very slow... some times it rise normally.
This problem appear not always and with random gear. Also i can push the clutch rise rpm (when i push clutch rpm increasing normally) and than try to drive with 2 3 4 gear. but i can't always drive like racer :/ Also i think this problem appears more often when its weather is cold ( in my country now about -3 -6 at night -10 by celsius);
I hope you will understand what i want to say... Sorry for bad english. I need help desperatle...
it looks fuel filter is clogged -- change it
EGR -- must be opened/inspected
I opened egr and cleaned. But i doubt can i use some cleaners so i think maybe i should make it again. And clean better with some special chemical. Hmmm , in service said that fuel fillter is okay. But i will try change it.
Had similar problem and fuel filter has just been changed which seems to have cured the problem.
Car has done 56,000 and filter should have been changed at 40,000, so only 16,000 miles use!
Hello i changed fuel fillter. it seems that problem has been solved :) if something will be wrong i will let you know :D
