Celica Gt4 St185 Stalls After Startup After 10 Sec
pink24
hi guys.st185 gt4.no codes.tested the pump.seems fine.new afm.car starts but cuts out after a few seconds.you can keep it running by pressing the gas but it smokes toxic fumes.any one had problems with this.its obviously overfuelling.im sure the ecu temp sensor is functioning because when i disconnect that, the car wont idle at all.any help would be much appreciated.
