Seat Belt Sign And Alarm On Event The Seat Belt Is Inserted
razvannbu
I have following issue, the seat belt sign is on and sound is beeping even the seat belt is on.
I went to the used car seller to check it under waranty an he did not mange to fix it, he remove the conector under the driver seat and the sound and sign is off, but the seat belt alerting is not working anymore.
I need a electrical diagram to check the cabling to fix it.
I start experiencing aove issue during driving he just started to beep.
Now I'm not sure if the airbags are properly functioning for the driver since the alerting system has been deactivated.
If the warranty is still valid, don't let the seller get away with disconnecting the sensor. Insist that they fix the problem. If they don't honour the warranty contact your local Trading Standards service.
If the car has been bought in the last six months, and it was not a private sale, the Sale of Goods Act should apply, regardless of the warranty.
