3 Degrees Beep!
grasshopper
Who else finds the 3 degrees beep a royal PITA especially as the UK weather is floating around this temp at the moment, then it goes up to 4 degrees and off the warning goes - then back down to 3 degrees and beep - today it did it 5 times in a 10 minutes journey - what a right pain and very distracting as well - is there any way to disable it so it only beeps once in a journey?
If you press and hold the cancel button it will go out and stay out until the next time you turn the ignition on. The later ones don't do that any more they just briefly show the message. Just think on - a short press will leave the warning triangle lit which is quite bright at night, you need a long press to disable it altogether.
Cheers Don - I didnt know that!
