Neons
Chuck04
Well at the mo ive got two neons in driver n passanger footwells which ive wired into the interior light, which im happy with, come on with doors open go off wen closed.. anyways i was thinking of gettin 2 more to go into the rear, under driver n passanger seats, can these be wired into the lights, so come on when i turn the lights on?? if not jst wondered what other options i have
charlie
I'm about to do just what you have already done. Where is best to tap into the interior light? If you can remember is it easy to get to and tap into? I did it on my old car and it was a right PITA!
just do the same again to activate the rear ones
Is it easy to follow the wires back to somewhere sensible like under the dash? Or can you fiddle the new wires down the roof lining easy enough? I havent had a good look yet but from what i remember the interior light is right in the middle so it would need some threading!
2 options, either from interior.. down door pannel along bottom door pannel, or top door pannel, simple to hide, jst pushes under plastic work, very simple
