Bluetooth Issues
Mkuk0
Ok guys and gals, time to pick your brains.
Just collected a facelift Prius T3, with built in bluetooth for calls and music streaming. have paired both my workphone- basic nokia, and my iPhone 4. When I jump in the car, both phones are shown in the system and one or the other is shown as connected. however when I look at the phone itself, neither actually confirm a connection ( ie little headset graphic showing phone is connected) any calls made from the car will fail, although the phonebook can be accessed. any calls made from phone will work as normal ie through phone not the car. Streaming music from the iPhone works fine, but I still cant make calls via bluetooth. If I manually delete phone from the car and re pair it, alls fine, until I switch off the car, then I'm back to square one.
Any ideas?
Cheers
Might be worth checking the manual but I seem to recall that the registration/connection for music streaming is seperate from taking calls.
Oh I've had a good read of the manual and it seems I've done everything right and it should just ...work. Buut it don't :(
Maybe a trip to Mr T today for advice.
Try deleting both phones from the car and reconnect them in the order of preference, the car will connect to the first one you enter first.
