Rear Brakes Comming On!
Ianmartin
Hi all, I have a 54 plate diesel spirit, had it about 5 weeks, nice car, a strange thing happens when going around right hand corners, islands and sharp bends, from about 20mph the back end digs in and one can feel the rear brakes come on, only for a second, i have tried turning off the Traction control but it still happens, i was putting it down to the cold temperatures we are having but to day at 11°C they came on again?
The car had new rear pads fitted 3 months ago by the previous owner.
Strange it only happens going around right hand corners, I am by no means a boy racer and some say I drive like my Nan.
Any pointers ? Cheers
IMC
Redditch
could be disc warpped or brake shoes inside brake disc! there is a rubber plug on the face of disc and inside that theres a wee cog put a flat end screwdriver in an turn the cog and check handbrake it could be sticking on...also may need new brake shoes!
Hi Frankie406, had a good look at the rears and all is well, I am thinking that this started when I had two new tyres fitted?? I have read hear that it may have to have the yaw rate sensor re calibration done. On other forums it can be done using a jumper wire in the OBD.
Any Idears?
cheers
ian
redditch
did u jack up rear and tried to spin wheels an see if they lock?... dont know about the jumper lead on obd..i have toyota diag tool i will put it on my cars an see if it has yaw on it..is your wheels lockin when driving or pulling/slowing car down?
have you tried your rear shocks are not gone on that side too?
All is ok with shocks and ok when rotated , it only happens when going aroung RIGH HAND bends not at any other time, the VSR light flashes on.
Thanks for the support
cheers
ian
best thing is to get it hooked up to diagnostic tool to check sensors..is there anyone from this forum who has toyota diag tool?
Ok, so I have read through this thread and now I'm concerned. At present this is an inconvenience rather than actually dangerous but:
if you are turning right across oncoming traffic and the brakes stick on you are going to be in big trouble really quickly - especially if the unexpected brake application causes the engine to stall. I know that this may not happen (and hope that it doesn't) but if it does you won't have to worry about fixing your brakes any more. Your front seat passenger probably won't have to worry about anything ever again.....
If it was me I would get it checked over by a professional, just to be safe. It will cost you but it may save you in the long term.
I think you are both right , most things I can do myself but this is a bit ...... iffy ...., I will get to looked at on Tuesday and let you know how it goes ' thanks and regards 'Ian
