Electric Window Knocking Sound
wah07
Hi All,
I was wondering if anyone else has this issue and knows what it is.
I have an Avensis t4, All the electric windows work fine they open and close perfectly. The only issue is that on the drivers window when I press the switch to move the window up and down it sounds notchy and when the window is on its way up just before it closes there is a knock sound as if something is hitting the window. Please help?
Thank You
Try lubricating the window channels with some silicone spray - not WD40.
Hi FROSTYBALLS,
I lubricated the window seals with silicone spray this morning. The noise seemed less but has come back.
Wonder what it could be...
