2004 D4D T3-S Timing Belt Change Tutorial
kashbg
Hi there,
Can anyboyd point me out to a good step by step Timing Belt Change Instructions. There is a You Tube video of an Irish bloke but it is a bit vague.
I would like to find out as much as possible in details before I atempt to do it myself. I was surprised that you actually have to lower the engine from its bay and have it supported so that one can get access to ...
Also, there is a Loctite glue used for smthg.
Anyway, if anybody has a service instruction or any tutorial, I would be gratefull.
Hello,
everything you need to know and more is in this attachment, go to section 14-305 for the timing belt for the d4d .... it's near to the end of the pdf.
Regards and good luck
Pete.
ENGINE MECHANICAL.pdf
