Idle Speed
big al your pal
Can you ajust the idle speed on Auris t 180 is there a automatic choke on this car and can it be altered :disgust:
There are no adjustments that can be made I'm afraid it is all controlled by the engine ECU, why do you want to adjust it?
Hi the reason being when cold the reves are high at times you can take your foot of the pedal and it goes its self untill it heat up i was going to turn it down i was geting 28 miles in town but after cleaning the engine with wd40 coverd it my milage went up to 38 in town after two weaks it started to come down so i covered it again it went back up so i was going down the line i must be hitting the choke thanks
