How To Reset Ecu?
Auristi
Hi
I found this guide, send by Daveyonthemove
"Reset the ECU. There is a fuse under the bonnet for the ECU which will
keep all other settings on memory, but reset the ECU. I can't recall
from memory which fuse it is, but your handbook will be able to help.
There are 3 common methods. 1 is to remove the fuse and then pump the
brake peddle a few times in order to discharge any electrical current
that could retain memory. replace fuse and drive economically and hope
it learns this style of driving. 2, remove fuse and leave for 30+ mins."
I try to find the right fuse, but I am not sure, what fuse reset the ECU. Is it EDU, EFI MAIN or ECU-B3?
My question is, what fuse reset the ECU?
My car is Auris 2.0 D4D, -08 (1AD-FTV)
