Leaking Convertable Roof
Heatseeker69
hi there I drive a 1995 gt convertable which is parked outside ..after heavy rain when i drive off water pours out of the bars on the drivers side and the footwells fill up with water.Has anyone else had this problem ?? i know these are quite rare cars.. Also any hints on changing the rear shock absorbers
Check the rubber seals that run down the screen frame, carefully run a wire coat hanger down with the end rounded of so it no snag.
Keith
