Hi, can anyone tell me where to find the dipstick for the automatic transmission oil level (Pics if poss)?
Thanx
There is no dipstick, the transmission is actually a manual gearbox with electric motors that operate the clutch & gear shift. To confirm the fluid level is correct remove the fill plug on the side of the transmission and add MT LV 75 gear oil until it spills slowly from the fill hole, if you want to change the oil remove the fill plug then remove the bottom drain plug and empty the transmission then replace the drain plug and fill with MT LV 75 gear oil until it spills from the fill hole.
Thank you for taking the time to reply and for explaining about the gearbox. You have answered my second question about the type of oil as well. Thanx again!
