Passenger Airbag
VXTim
Hi
Can someone please tell me how to turn off the passenger airbag please?
I am planning to put our baby seat there.
The rav4 is a 57 plate.
Tim
Hi Tim,
On ours there is a switch on the side of the dash.
If you open the passenger door you can see it..
You need to insert the key, twist to the 'off' position, then remove the key..
The display on the centre warning changes to let you know..
If you need more info, let me know..
Can post pic of switch if required..
HTH
Hello Tim. Open the front passender door and you will see the 'switch' panel on the end of the glove box. Use the key to switch off. When you switch on the ignition the tell tale light just above the right hand heater control should show that the airbag is switched off :thumbsup:
Yeah, wot he said!
Edited by Davrav
  • 3 years later...
Hi - I don't suppose anyone knows how to disable the front passenger airbag on a 2003 model?  It doesn't seem to have the side key referred to above.
Thanks!
  • 3 years later...
Anyone know how to turn off on a 2019? There’s no side panel...
Edited by FROSTYBALLS
Shouting removed
Should be covered in your owners manual. You can also download the full owners manual from My Toyota.
P48 in my copy of downloaded manual (obviously diagram for Left Hand Drive model, so in UK will be on left end of dash, visible when door is open):
