White Smoke
cohen
Apologies if this issue has been raised before. Sometimes when I start up white smoke billows from the exhaust, has anybody an idea what is the cause. Choked the wife the other day, not a happy bunny.
Loads of chatter on here about white smoke. Loooadsssss......
Check and monitor your coolant. If the levels aren't dropping then it is likely to be simple condensation from combustion - but it shouldn't be too bad in the warmer weather.
