2007 Auris Front Fogs Into Drl's
glasform
I have changed my front fogs into Day Running Lights by buying an LED- H11 bulb DRL kit from the web site attached, fantasticly easy to fit, with only four wires to connect, very bright white light, and turns off when dipped headlights are turned on.... give them a try but make sure you get the correct numbered bulbs ie. H11 or HB4, but I had to use H11's as these are the ones that were in my fog light...so check what sort you have before you order.
http://www.ledcom.co.uk/fog_lamp_conversion_kits
Just to add to the last post I made, that I did order the wrong size bulb kit before I purchased the correct one (H11), so if you need a fog light conversion led kit for your Auris or any other car that uses HB4 bulbs, then I have an unused, new, HB4 LED conversion fog light kit for sale at under the recommended price.
HB4 Fog light conversion kit for sale for £23 + £3pp. If your interested send me an email to...
piggyporter@yahoo.com
Tony.
