Air Noise When Accelerating
barracuda
Hi Guys
Looking for a bit of info on the above
As title says. when i accelerate above 1500rpm i get an Air noise from around the drivers side. Which i can only describe as a whoosing sound(noisy air)
could this be a split pipe of any sort? any ideas where to look?
The EML came on last night but has came back.
It doesnt make the sound when reving out of gear.
thanks
Check that it has a genuine toyota air filter and then the pipes from the turbo back to the intercooler.
Thanks anchorman. All checked and nothing apparent found. I did smell a bit of burning while at the lights yesterday. Think I will take it to MR T this week.
Double checked, you where right anchorman. Intercooler hose had popped off :-)
Had a new engine in or some other work done?
Yes replacement was fitted about 9mths ago, must have been slowly working loose.
Aye, not tightened properly.
