2003 Rav 4 Auto......keeps Losing Power/speed Then Lurches On.
hartsongs
This doesn't happen all the time but it's becoming more frequent. It's as if the car just dies and then springs into life again. This is an automatic petrol model. I'm at a junction. I pull out and the car goes from 1st to 2nd gear...then immediately loses power as if I've applied the brakes. It shudders before lurching forward accompanied by an almighty clunk. No problems afterwards as the car goes through the gears into higher speed. So it wont happen if I'm going at a reasonable speed along the road or motorway. It's only when I've stopped and then move off again. Before i take it in, any ideas or has anyone had a similar experience?
ECU gubbed, Paul......do a search, some very recent, re auto box ECU recons.
Kevin
Thanks for your reply. It seems that this is a common problem. If its ECU, then it needs changing fast and it would appear Toyota aren't coming forward with free replacements as it's a faulty ECU. If the damage goes as far as the gearbox then it's a big and expensive repair job.
Better get it sorted sooner rather than later.
Cheers
Paul
Where is the ECU located on my engine it is a RAV4 2003 DISEL WITH A MANUAL GEAR BOX;
Kevin
You were right on the money.
The ECU was removed and sent off for repair. It has been returned and re-installed and now the car runs better than ever.
The cost was about £200 but compared to a new gearbox etc so the cost is easily justified.
Quite peeved by the fact that the garage I took it to (40 years in business) didnt know what the problem was and could offer no help. I come home, looked on the internet and the problem/answer is revealed.
It just shows that these forums/clubs are fantastically powerful sites.
Cheers
Paul
Good result Paul.
Pity Toyota won't admit to this fault in the UK as they were forced to do in the US apparently.....................
Kevin
Cheers
Paul
Paul.....please edit start of your post....."you were right" should be in capitals, as it doesn't happen that often !!!!!! LOL.......
Stonking result.
Big Kev
