Touch And Go Phone Connection
vickk
Has anyone got any experience with phone usage and the touch and go system.
I followed the instructions and paired my phone no problem. It connected for music and phone without a hitch, loaded the phone book and used it to make a call and everything seemed fine.
the problem if that's what is is came when I got in the car next morning. The phone and the touch don't connect automatically, they are still paired but the only way they connect is if I make the touch discoverable and manually press the phone to connect to the touch.
All is OK until the next time I get in the following day.
My phone asked me did I always want to auto connect to "Toyota Touch n Go". I would go back to start again and await that question?
Big Kev
Yes - you have to tell the phone to do it.
Every time I get in the car?
Big Kev
Done that but made no diff
No, go into your phone settings then go connections then go bluetooth then go connected devices then when you find touch and go you should be able to set "automatically connect to this device". The wording might be slightly different but you will find it.
done all that up to the auto connect bit and it's not there. my phone auto connected to my old rav no problem
See....? DO NOT take this car on holiday......nobody will be able to phone you......I will look after as a favour, last offer.....
