If anyone can help me to get one of those Headers Please let me know Thanks!
Ready For The End Of The Year 12-31-12
Fenders Taking Sun 1-13-13
The Last Brake Line Connection Work 4-1-13
In Progress Ready With all Materials & Tools
Drilled and Fittings in Place
Doing the Flares on the Inside lines
What's left to the front of the car...
Flares Done Under the car to the OEM Brake line to the rear brakes and connected
Finished connection inside the car to the rear brakes...
  • 4 weeks later...
Getting Ready To Bleed 4-4-13
My homie Josean DK come with the important materials to bleed the brake lines
New Brake Master and Bleeding 4-6-13
Getting Ready to bleed the brake lines...
Remove the Wheel and open the Bleeder
Filled but No Brake Fluid Out of the Master Cylinder
Removed Reservoir for Inspecting and Cleaning
My Homie Beto Come to help on the Bleeding Process
Old Brake Master Cylinder was defective, Just Buy a New One...
Doble Check All Fittings and Conections To Avoid Leaks...
That's Me Doing the Bleeding Process with the Brake Pedal Everything was Great, with no Leaks!
Dude your steering wheel is on the wrong side... :)
LOL :driving:
Late Night Transport 4-7-13
The Car is Ready At the Trailer...
My Kid Gabito Is Ready For The Trip!
After Few Hours one Stop prior to Up Hill to make sure everything is ok and belts are tight...
Arriving...
Leaving the Trailer With the Car on it...
Night Work At Maniatico AutoPaint 4-7-13
EG Relection on My AE101...
Me Doing Work...
Leaving the Car With The EG...
Long Trip Back to Home... The Taco Needs Refill...
Toms Wheelset Redone Work 5-2-13
Disassembly the Centercaps...
Choosing the same powder coating as this other Drag Wheels
Tom's Original Finish
Center Caps & Valve Stems Removed...
Toms Wheelset Redone Work Part II 5-7-13
Sand Blasting to the Wheels
Toms Wheelset Redone Work Part II 5-8-13
Fixing Small Imperfections on the lip
Brake Brackets Received 5-11-13
Brake Calipers for Brake Upgrade Arrived
The big stuff :driving:
Are you stopping a tank ?... ;)
Yeahhh! :)
Nope... I'm going to use it for track and the OEM USDM Brakes that come with it and the 4AFE engine is not good for it.
Removing Oxidation of Brackets 5-13-13
Cleaning n Get Ready To Paint 5-14-13
Painting Brake Brackets 5-17-13
Corrosion Protection
Nice job :thumbsup:
Nice job :thumbsup:
Thanks Man!
Toms Wheelset Sandblasted 5-20-13
OEM Engine Harness 5-18-13
Engine Harness For New Swap Conversion Harness
46 Toms Center 5-20-13
Looking To Get New Bolts
Disc Rotors Arrived 5-20-13
