Help Needed
Craig342
Hi, hoping someone here could possibly help, my 02 celica has been sitting for a while, just went to start it and it seems the Battery is dead, problem being I can't open the doors, key fob is fine Battery wise but the car lock does nothing, lights don't flash nothing. How can I get in? At least to pop the bonnet and jump start or replace the Battery if needed? Any help is much appreciated.
Yeh if you disconnect and reconect the Battery with keys in ignition, cental locking normally activates, thats why I always roll window down when disconnecting any Battery.
So same problem, Battery flat no power to work central lock, why cant you get in just using the key in the lock? is the locks all broken or something?
