2005 Avensis Multi Display Dark !
Reggie83
Hi guys,
I just want to ask if that display in my avensis with MPG readings is working but you can't se it at night.. should it be lit because it was like that sins i'v had a car..
Mine lights up when I put the headlights on.
I suggest you let an electrician have a look at it. Could be a simple fix.
Probably the bulb(s). I believe to remove it you access the screws by removing the trim which houses the rear window demister and cupholder. It simply pulls off towards you, start at the passenger side.
Thanks for replies I took out all unit other day but could not see any bulbs unless they are enclosed inside casing...
