2005 Avensis Antenna Amplifier
johnro
hi guys
any chance you can help me with the location of the antenna amplifier for a 2005 avensis?
i have to check to see if it's connectes propperly. i'm hearing a lot of hissssssssss's lately and it's very annoying
thanks guys
There could be a break in the heated rear window wire on the glass check that first.
Pete.
i have tinted windows from when i bought it (almost for 8 years now)
the defrosting ones are working perfectly. all of them :)
any other ideas?
thanks for your time
any other ideas?
If your car is a hatchback the amplifier should be located in the tailgate under the plastic trim or maybe the aerial cable is damaged due to opening and closing over the years.
Pete.
my car is a saloon car :)
I have some info on one of my other computers so I will have a look tomorrow and get back to you :yes: .
Pete.
Hello again Johnro,
I have attached a .pdf file which covers all aspects of you problem.
Regards Pete.
AUDIO & VISUAL SYSTEM.pdf
one more thing, maybe you can help me with
is this an active amplifier or a pasive one?
i managed to play with it a little bit but i couldn't find the power suply (if any)
thanks again
hi guys
can the radio condenser be the problem here? :)
