Can anyone post or send me TOYOTA original inbuilt DVD player?
Regards,
Do I take it you need to replace your original player.
If it's a new player you require there is a replacement player available which is almost the same.
  • 11 months later...
Hi, I'm interested in this as my DVD player has given up and requires replacing. Thank you.
  • 5 months later...
I have a 2004 verso.my incar dvd is not working with the inbuilt car Speakers.How do you select from the dashboard controls so you can use the incar Speakers?
Sent from my iPhone using Toyota OC
I have a 2004 verso.my incar dvd is not working with the inbuilt car speakers.How do you select from the dashboard controls so you can use the incar speakers?
The in car rear DVD screens are not connected to the car audio and can only output sound via infra red headphones.
  • 7 months later...
Anyone confirm a replacement for the Verso, also are they easy enough to install
