Where Is The Oil Filter Location On An 09 1.4D4D
lmcc87
As per title I've done a lot of digging and cannot find where the oil filter on the 1.4d4d is located on the 09 onwards auris'. Under the car or hidden in the engine bay, anyone help? Thanks
  • 11 months later...
For anyone looking to know the answer to this, if you remove the plastic engine undertray you will see it just off to the left of the centreline of the car. You will see the black filter housing where the oil filter sits within sticking out a slight angle also pointing towards the left hand side. Very simple to find once the under tray is off the car.
