Rav4 Reversing Sensor Configuration
grasshopper
Hi Guys,
Not sure if you guys have the laserline 4006d reversing sensors fitted - but that is what mine came with. Anyway, I had to replace the rear bumper and managed to fit the senors in the wrong order so they were beeping like mad. And then I accidentally switched them off and after 3 hours of hunting for instructions I found them here:-
http://www.apri.cz/download/FBSN-4D_EN.pdf
Seems pretty good as you can switch them off without having to have an aftermarket switch and even change the range of detection! Which is great as I now don't have the mexican banjo's when I reverse.
I'm sure someone will find them useful.
I take it nobody has these then.
