Problems!
Ryan1985
My driver side electric window works fine apart from wen it has only the last cm 2 go wen it starts 2 creak and doesn't close quickly! Its as if it wants 2 go up further but can't manage it! Happened on my bro's car and his window came off the runner, could this be the same problem?
And my exhaust makes a horrible noise, kinda creaking and rattling but i've check and its not loose, is it on its way out? And is this expected after 4 years and 35,000 miles?
Cheers :thumbsup:
About the window: If you watch closly when putting the window up, in the last 2cm the bottom of the window actually moves about 1cm closer to the outside of the door. So maybe the problem is that it can't move outwards so check the seal to make sure its not in the way.
As for the exhaust I'm clueless :wacko:
Moxy.
ive have a creaking/knockin from the rear too
cant figure out for the life of me why tho
try dabbin a lump of grease or coppaslip on the tailgate catch
i had somat creaking for months and tried everything until i wiggled the boot lid once and heard it do it.
hi
yeah tell me about it had to redo mine at 6 today blasting thing.... :ffs:
