Gt4 St205 Map Sensor Help
Torchymt
Hi Guy! I need you help and advise!
First of all i have a Gt4 St205
And My Map sensor broke..
and i can't find a original map sensor, it cost a fortune to get one here in malta. :/
and my mechanic said a glanza map sensor will work good.. and here in malta glanza's are common so parts are cheap.
My question is : does a glanza map sensor work good on my gt4?
so long as the connections are the same , id imagine it would work , its only a pressure sensor and pretty standard across most makes . some sense 2 bar others 3 bar , you'll soon know if its no good .
