Avensis Clutch Pedal Not Returning
Farmerpug
A friend has a 2004 or 5 avensis 2.0 D4D and the clutch will not return, i checked around the clutch pedal, the spring is good, around the gearbox, under the car there is hydraulic fluid leaking out, how do you get at the clutch slave cylnder on these cars, the engine bay seems cramped compared to my 406.
Also there is a rattling noise coming from the auxilary belt area, a clattery noise, do these cars need crankshaft pulleys, my 406 did and it was making a similar sort of noise.
By the way, this avensis has over 200k miles on it
click on the link below.
http://www.toyotaownersclub.com/forums/topic/120775-05-avensis-clutch-pedal-squeak-l700/
t-spiritpete has attached a pdf file on the avensis clutch.
rattle most likely to be the aircon. this can be bypassed by fitting a belt from the earlier avensis without aircon if you still want to use the aircon you will have replace aircon unit.
